65 dart gt 225
Old Oct 27, 2008 | 06:09 PM
You will need a 1/2" breaker bar and a good, six point socket. You might need a small extension too. The engine must be HOT before you adjust the valves. You want the engine hot to allow for expansion. This was always stated in the shop manual.
Bar the engine over to get each cylinder to Top Dead Center (TDC). When you're at TDC there will be no tension on the push rods and springs. Adjust the intake to .010 and the exhaust at .020. Don't mix them up.
If you can't bar the engine over you can bump the starter by jumping the starter relay. It takes practice, but, you can do it.
Remember, tight adjustments can cause push rods to bend. Loose adjustments are noisy, but basicly harmless.
Arcadiax
Mar 22, 2012 03:19 AM
deshu2011
Aug 22, 2011 03:57 PM
restoll
Oct 17, 2009 09:30 PM
johnthegoalie
Sep 9, 2009 06:56 PM
nicolette
Dec 19, 2007 12:13 PM
