72 charger - help with gas tank replacement
Hi all,
I've got to replace the gas tank and I've sourced one as well as the mounting straps. My question is, is there anything else I need to get? any seals or anything? Thanks much, Joe |
if your new tank dosnt come with the sending unit rubber seal and the filler tube seal you will need them . You may need new hose clamps for the lines also
