Mopar Forums (/forums/)
-   Do-It-yourself Section (https://moparforums.com/forums/f6/)
-   -   73 Roadrunner gauge bezel (https://moparforums.com/forums/f6/73-roadrunner-gauge-bezel-12039/)
timnez123 Mar 30, 2012 06:31 PM
2 Attachment(s)
Any ideas about how to fix my gauge bezel? I have another bezel where the radio part is good. Is there a way to cut and fuse this plastic? Hard part to find, Anyone know where to find one, I have not had any luck. Thanks all, Tim
Archer Mar 30, 2012 07:28 PM
Tim -
They do show up on eBay, but they ain't cheap.
Depending on how good you are with plastic, you can get sheet styrene at most hobby shops, trim the bezel square and insert and glue in a new piece. You should cut the holes for the radio first. You can also use fiberglass body patch material, but again, depends on how good you are with that stuff.
One of our local restorers does alot of that kind of stuff, including custom bezels.
timnez123 Mar 31, 2012 06:28 AM
Thanks for the reply. Im ready to talk to about anyone who does this. I live out in the country and am busted up from the Marine corp. I do 90 percent of my research from a computer. Miss the old days hitting the junkyards. Do you have a number for me? That would be great to put this to bed. Also wanted to swap the clock for a tach. This form is awesome. Thanks again, Tim
Archer Mar 31, 2012 07:29 AM
Tim -
The guys I've used are in NY (Long Island). The place is called Auto-mat. If you want to talk to them shoot me a PM.
