86 360 5.9 rebuild advice
Hey there!
I just purchased my 3rd van and this is the second one to have a the engine take a poop on me. i feel a little daunted so I was wondering~ How easy it is to put in new piston rings? If I'm doing piston rings should I just rebuild my entire engine? How easy is a rebuild on a 360? Im a little handy when it comes to mechanics only because the community on this forum gave me the confidence to do the work, but I am fairly new to this work. thank you for everything! |
I would say stick with just rebuilding the motor....
If you had top notch mechanical skills yes re-ring just to get by, this was normal for a mechanic to bang this off and grind valves and seats in one working day, engine block in the car.
A total rebuild is the "easier" way to go with the machine work done by professionals the assembly could be handled with guidance for someone with your skill level. I would suggest though, when you go to price this look at having the short block assembled by the machine shop or trusted, knowledgeable mechanic and do the rest yourself. |
There was a time maybe fifty or sixty years ago that a a rering with a block in the car would have been the normal way to go. Now its hard to get a shop to rering a motor...........
Labor cost to much to R and R a motor to do a half ass repair and the public expects miracles for nothing, nada, no dollars and stand behind it. Fix correct or junk it......... |
Remove the motor !! Much easier to work on it
