Aftermarket air cleaner
Old May 20, 2023 | 08:02 AM
Dcmurray70's Avatar
I have a 72 Dodge D100 and I want to put aftermarket air cleaner on. Factory cleaner attaches to engine with three air hoses, what do I need to do with those?
Old May 20, 2023 | 08:41 AM
dodgem880's Avatar
The vacuum lines will need to be disconnected from the air cleaner and plugged to prevent a vacuum leak. If your still using a carburetor with an automatic choke make sure the choke pull-off stays connected.
A larger hose may be running from the crankcase breather. Your aftermarket air cleaner may or may not have previsions for this. The breather itself should have a filter in it so I don't think most people connect it back when using an aftermarket cleaner or they switch to an aftermarket breather. Just be sure not to plug off the crankcase breather.
Blackbird
Feb 12, 2019 04:50 PM
2bentrims
Nov 26, 2015 08:36 AM
TGC
Dec 19, 2013 03:10 PM
mopar318
Feb 18, 2013 07:22 PM
BuckNeccid
Nov 3, 2008 02:33 AM
