Best way to empty old fuel tank of gas?
Old Jun 26, 2012 | 10:27 PM
Rumblefish318's Avatar
I just bought a 1974 Dodge Charger ($700) and I am attempting to start the engine. It is a 318 and it hasn't run in 4 years. I tried to pump out the old fuel in the tank with the Harbor Freight hand pump, but the anti-siphon device in the fuel pipe prevented the hose from entering the tank. The tank is on "E" so it's almost empty. I don't want to pull the tank. Any ideas?
Attached Thumbnails Best way to empty old fuel tank of gas?-012.jpg   Best way to empty old fuel tank of gas?-015.jpg   Best way to empty old fuel tank of gas?-009.jpg   Best way to empty old fuel tank of gas?-006.jpg   Best way to empty old fuel tank of gas?-007.jpg
Old Jun 27, 2012 | 05:28 AM
62Furious's Avatar
crawl under car and remove fuel line from tank, use rubber hose and electric pump to siphon old gas from tank
Old Jun 27, 2012 | 06:28 AM
Could just drop the tank. It would allow you to see what kind of work (if any) may be needed to be done to the floor from the underside too.
Old Jun 27, 2012 | 07:53 AM
MrOldart2U's Avatar
X-2 on the electric that 62 mentioned, but if it has that small amount of gas I'd be inclined to bite the bullet and drop the tank... 1. you can empty it 2. you can have a look-see in tank for 'crud' 3. it can be rinsed out easier if it does have a build up of gum/varnish. And of course you can then see the aforementioned possible trouble areas for rust....
OR you can just pour in 10-15 gals of gas and HOPE it will dilute it enough to not cause problems( very doubtful)
Plugged filters/carbs are never fun....
M2C
Old Aug 29, 2012 | 10:19 AM
Beepbeep71's Avatar
You can make it look like the burn notice car!
motasupra
Apr 17, 2015 07:48 AM
Justin123shory
Mar 8, 2014 08:31 PM
Demonized
Jun 17, 2010 06:21 PM
ngc414
Aug 31, 2009 01:27 PM
reilly
Aug 5, 2009 04:23 PM
