Dodge getting too much gas
Guest
Posts: n/a
Hi, all this should be an easy question to answer. Ive got a 1979 dodge aspen 318 4 barrel with electronic ignition. The problem is the engine keeps fouling plugs. It has new plugs, high performance plug wires and a rebuilt carter carb, (can't remember the model number). The mixture screws are set at 1 1/2 turns out. Would appreciate some help thanks.
There are many, many things that can cause plug fouling, besides the carb.
First, are you sure it's gas fouled and not "burning oil?"
What do the plugs look like? Describe the color, or can you post a picture?
Are all 8 plugs the same? Or are just a few, or one or two fouled?
You might have gotten the wrong plug heat range.
Does the engine idle and run smooth, or does it idle ragged, same with low speed cruise?
Is the car running up to temperature? That is, do you have a thermostat, and is it allowing the engine to come "up to" temp?
It might be a problem in the EGR system, or you might have a PCV valve stuck open
IF it is the carb, it is probably not the idle circuit per se. It might be a leak in the carb--I hated Carter "Thermojunk"
In the case of the older Holley's I've found MANY leaking power valves--brand new right out of the "rebuild kit."
Carters don't use that type of valve, but the metering rods might be stuck with the needles pulled clear out of the jets, allowing a rich condition.
It's been a long time since I've had a Carter--and you need to find out, is it an AFB, an AVS, or a Thermoquad--it IS a 4bbl? or is it a 2 bbl?
Anyhow, most of the Carters used a vacuum operated piston with a spring underneath. The high vacuum pulls the piston down, and pulls the needles (which are tapered or stepped) down into the jets, to lean the carb out for idle and light cruise. As you apply throttle, the vacuum drops, the spring pushes up the piston, the needles start to come out of the jets, and they effectively get larger for more power.
There are many questions here, before you condemn the carb
Guest
Posts: n/a
first, yes i'm sure its gas fouled. I have checked all of the plugs and it seems to be fouling only some cant remember which ones. The color of the plugs are black and carbon fouled. The engine idles and runs smooth till i put it in gear and try to drive it. Yes i do have a thermostat it seems to be coming up to temp but not sure. I removed the egr valve when i upgraded the ignition. I did notice a problem with the metering rods the other day, one was spilling gas out the top. pulled the top of the carb and adjusted the float and it keep repeated itself. I looked at the float and it was pretty beat up so i decided to swap out the floats for another carter afb even though the floats that were in that carb were larger than the ones on the car. could that be my problem along with the metering rods. It is also a 4 barrel afb.
If fuel is spilling over the top, you most likely have a float/ needle and seat problem, rather than metering rods.
If this has a foam float, they can become waterlogged, and of course brass floats can leak.
You might have a poor needle and seat, one that is letting fuel seep through.
Also, are you running any kind of "performance" fuel pump? Any chance you have too much fuel pressure?
Guest
Posts: n/a
I fixed the problem with the floats, just needed adjusted, and yes the fuel pump is a performance fuel pump that is a manual, could too much fuel pressure be messing up the carb? Also the fuel filter doesn't fill up like any of my other vehicles do. Don't know if that's a problem or not just wondering.
Yes, could be too much pressure. You should be able to buy (still yet) those combo vacuum/pressure gauges at the auto parts, and they are occasionally handy to have around. Look up the pump you bought and see what it should have for pressure.
Frankly, though, I doubt the pump is the problem. There is only one way to be sure--check the pressure
Again, I've said this before--as old as these cars are getting to be, suspect almost ANYTHING
My old books of course shows higher pressures for the higher performance engines.
For HP 440's it shoes up to 7 1/2, and hemis shows up to 8 1/2. I'd forgotten that any were that high.
I'd say that if you have an old needle and seat, that anything above about 6 is suspect. Certainly anything above the hemi spec is not good.
Here's the thing about mechanical pumps. The pressure is not generated by the cam lobe, it is generated by the spring in the pump. When the cam actuates the pump lever, nothing happens. The SPRING in the pump does the work, and so this means three things:
It is the spring in the pump that determines pressure
When the line builds up, as at idle, the lever starts to "float" of the cam lobe because of fuel pressure, and thus doesn't do as much work
If you run an electric pump in series, the electric doesn't add much pressure, because all that happens is, that the mechanical pump arm starts to float, and adds nothing unless it's needed.
As I've said before, as old as these cars are, suspect anything. Take a critical look at the floats and needle and seats.
Guest
Posts: n/a
well i picked up a fuel pressure gauge and put it in the lines and found that it was getting about 5 psi. After messing with the floats and and idle settings for a while i got it to run better(still occasional will die). I noticed when driving if i put my foot in it the secondaries don't open up right away if at all. If they do theres a hesitation. Could this be a carb problem or could it have something to do with not hooking backup up the trans kickdown linkage when installing the 4 barrel?
frogjumper
Mar 20, 2011 10:05 AM
Foedoe
Mar 8, 2011 07:47 AM
rcknrolfender79
Mar 18, 2010 11:02 AM
