Eastwwod's internal frame coating
Old Mar 11, 2011 | 02:44 PM
Eastwood's internal frame coating
I am going to get me some of this...
Internal frame coating is formulated to convert and encapsulate the rust INSIDE your frame. Our formulation also incorporates zinc phosphate to further protect the metal from future corrosion. The viscosity is stabilized to assure proper flow and penetration to the existing corrosion and will yield complete coverage when sprayed with the included "conical nozzle". Easy to use, must have product, that is aerosolized to simply spray the entire inside of the frame with the supplied extension tube and "conical nozzle" for complete coverage and elimination of the rust for years of protection. Fully cures in 24 hours.
http://www.youtube.com/watch?v=cm7W7Db5vdw
Old Mar 13, 2011 | 07:27 AM
bboogieart's Avatar
Things that make you say HMMMMM!
Waiting to hear back how it worked. Will it work on inner fender panels like the seam between the outer rear quarter and the trunk extension panel ?
What do you do about scale inside a frame rail? Seems kinds like an aerosol version of por 15 huh?
Thanx for the link.
bboogie
Old Mar 18, 2011 | 06:09 PM
scotts74birds's Avatar
Interested in the outcome also! Along the same lines, at the factory, starting in 2001, we started using a "Purfoam" system for our rockers. It is a 2 part, closed-cell, expanding foam we inject into the rocker space. It dampens the BSR's [buzzes, squeaks, and rattles], and NVH, [noise, vibration, harshness]. Since its a closed-cell foam, it does not absorb water, and adheres to the metal. In a nut shell....It is a form of "Great Stuff"!! I'll be fixing the rockers of my Ram this summer and will try to "Great-Stuff" them. Since I'll be painting it the Army "woodland camo" pattern, I wont care if it doesnt work!
Old Mar 19, 2011 | 03:45 PM
Internal Frame Coating w/Spray Nozzle
did you try it yet bremereric?
Old Mar 20, 2011 | 08:22 AM
Guys I just got it Thursday...I have been busy stripping the paint out of the engine compartment...there are two places I am going to use it...in the cowl area and for know the front frame rail areas in the engine compartment...later on when priorities change I will do the remaining frame rail sections...I can best show you how it works when I do the cowel area...soon
Old Mar 21, 2011 | 06:15 PM
m880cummins's Avatar
I got this stuff last month and am very satisfied! I did all the channels of the cab with it and it is awesome stuff and would do it again in a heart beat. Just be careful with the 360 degree nozzle because it goes everywhere and is hard to get off your skin. I almost got it in my eye and put goggles on right away. Here's some pics of the cab I did for my truck:
Cab:
Frame coating:
Good idea is to zip tie a piece of brake line to the flexible hose because it will be more of a wand then a limp thing. I can fish that into the rockers and get full coverage. When you hold it upside down to clear it make sure you hold onto the nozzle kit because you can put it on any rattle can. I used the frame coating on the precious stuff like rockers, cowls and inside of the drip rail and then used store bought primer on the rest as the coating is $20 a can. I bought 2 and you will get carried away....
I like this stuff because it is thin enough to creep through any seam but will get hard as a rock. Just make sure you do it on a surface that you don't care if you have overspray because you want it to leak out to ensure full coverage.
Charlie
Old Mar 21, 2011 | 11:49 PM
See I like your reply....how did the color change after 24 hours...I have pic of rust and will post some of what it looks like after I do it and 24 hours later....thanks for your reply
Old Mar 22, 2011 | 02:42 PM
Looks no different after 24hrs. The stuff was dry really quick and I was painting over it in 2 hours with no problems.
Charlie
Old Mar 23, 2011 | 11:23 AM
Thanx for the link.
bboogie
Okay I used it last night in my cowel compartment which was really fun to hit all of the spots and then the front frame rails...In the frame rails it was much easier because they are a rectangular tube versus an more open space...I probably over covered the areas but oh well...on the frame rails I used it until I saw some dripping out of the holes..before it dries any overspray can be removed with mineral spirits or laquer thinner..
Old Mar 23, 2011 | 01:15 PM
did you find it easy to use?
Old Mar 23, 2011 | 01:24 PM
Frame rails is a no brainer....cowel was a different story...but it does say frame rails on the can..
1966DartConvertible
Jan 16, 2011 02:56 PM
69POLARA383
Oct 9, 2010 06:03 AM
dodge610
Aug 25, 2009 07:13 PM
jar84203
Jun 18, 2009 10:39 AM
