Help With Larger Wheels!!
Hey guys! So this is a repost i made early in the Wheels and Tires section, just figured there would be more footsteps on this side of town.
I recently purchased some 15x8 5x4 1/2 wheels for my 1970 Duster. I knew my bolt pattern was 5x4 but i got them both + tires for 50$. I then bought wheel adapters off summit for 60$, (So just the back 2). And the Tires on them are 275/60 on 15's of course. The problem i am having is the scraping on the fender, as you probably guessed by now. So far i have grinded a little off the edge of the fender, and made some leaf spring extensions, raised it about 2 inches. The car will now only scrape on big bumps/ speed bumps. I'm trying to figure out if i should just try to re sell them, and go back to my baby 14's in the rear. Or if there is some more i can do at a lost cost to keep them back there, because i really do like them. Is it possible that if i just lower the tire size i would be in the clear? Let me know, thanks guys |
Hi there I have a 74 satelite,it's got 15" centerlines on it the fronts are 195 and backs are 305 mickeys.I have also put extensions on the springs.But yeah the problem is it's got a big rake on it(I think someone has wound the frount down) if I was keeping it I thinkid put smaller wheels on it now.
Are you interested in selling the centerlines? if so where are you located
Originally Posted by JayceDUSTER
(Post 114379)
Yup all the way down here.Wish I could have helped,
