Help with Tune Up
Hello Everyone,
I am wanting to do a tune up on my 1971 Dodge Charger SE 383 6.3L. However, not sure what kind of spark plugs or wires to get. Can anyone recommend? All original. Thanks! |
Are you going for a stock look or performance? I like Champion plugs cause they're made in the US, but any name brand plug is fine. I use black 8.5mm MSD wires, universal set and then I cut them to fit.
Just buy good parts....
Service And Safety inspection every 3,000 miles And Major Service & Tune up every 20,000 Handle the little things in-between... And Things will be great :):) |
Stick with conventional Champion, autolite, NGK, none of the Bosch platium and such.
Good quality wire! Do you have headers ? Wire routing is critical if you don't want to burn plug wires |
Thanks for all the responses!
Would like to go performance route for plugs and planning on getting MSD wires. No headers. |
Thoughts on Mallory Pro sidewinder wires?
Mallory makes good stuff also..
the msd kit where you make your own wires is what I use currently. I love that I got to choose length and could add in a few "wire clips" to hold them in place where I want them to be.
DO NOT BUY E3 spark plugs. I wasted my money on them. they were awful. Especially seeing as they were about $40 more for the set. |
Originally Posted by 70newport
(Post 115387)
The best bang for the buck on a mild engine is Belden plug wires from Napa
I also like Accel Super Stock 8MM Wires,,
Originally Posted by Mr.4spd
(Post 115388)
I've never tried them. Were they awful because they were expensive and no better than the rest?
Just my experience. :) |
Hummmm..... I have the worst luck with Champions...
| All times are GMT -7. The time now is 05:57 AM. |
