i wish i had sludge
Old Apr 3, 2009 | 10:17 AM
craveman's Avatar
Senior Member
i wish i had sludge
i started swapping my intake today and when i pulled the old one off i noticed that it didnt look right. then upon closer inspection i noticed that there were chunks of old oil and gunk all over my pushrods. not little tiny clumps. some of them were the size of golf *****. my engine has been running fine so i assume my oil pump is still working but i cleaned it all out and filled a 2 liter soda bottle with clumps of oil. but this car did sit for about 11 years before i got it. ive been changing the oil regularly but i guess ill put some oil system cleaner in it from now on.
Old Apr 3, 2009 | 02:35 PM
just try to clean up whatever you can
Old Apr 12, 2009 | 03:50 PM
rr69half6bbl's Avatar
yeah, the 80`s 318s are bad for that, they tan lean due to the lean burn crap. so the heat rises didnt work good and all the oil laid around the lifter valley, and thats what you get over time. after you get the intake done, then run a quart of tranny fluid in it with the oil for 10-15 minutes, then drain the oil,and change the filter, and watch the assfault roll out of your pan.the trans fluid is a strong detergent and itll wash alot of the excess of the lifter vally and rails.
Old Apr 13, 2009 | 02:30 AM
Polaradude's Avatar
That works good, I have used diesel in the oil also for the flush.
Old Apr 17, 2009 | 02:15 PM
Polaradude's Avatar
Last time I checked diesel was an oil, and i wasn't saying to leave it in there for 6 months.
Old Apr 17, 2009 | 04:13 PM
i really dont find there to be a difference between diesel oil and just regular oil
pro-tech
May 11, 2014 02:11 PM
mopardrt
May 9, 2010 04:16 PM
Crazy4Carz.Com
Nov 21, 2009 09:07 AM
Crazy4Carz.Com
Nov 6, 2008 05:31 AM
