mr340 |
05-09-2010 04:49 AM |
Yes, it has the rubber gasket, The install is not difficult. I set the gasket in the frame, using a piece of rope rubbed down with a bar of soap, (don't use liquid it's too messy to work with) place the rope in the window channel starting at the bottom center and ending at the bottom center, place the glass in the opening, setting the bottom in the channel, start pulling the rope out slowly while gently easing the glass into the channel. Don't push too hard on the glass or you will break it. If you don't get it in on the first try, just start over. Remember TAKE YOUR TIME!
