?interior paint?
Old 03-17-2009 | 10:21 PM
mike639's Avatar
?interior paint?
hey guys i need some advice on this one. next week i am going to start pulling the interior panels of my 73 satellite. its currently yellow and i want to switch it to black. i want to do the work myself to save some . what paint do i need and how do i go about applying it? parts of the panels are plastic and some are vinyl, so can i use the same paint/dye for both? any point in the right direction will be appreciated
Old 03-18-2009 | 03:33 AM
Polaradude's Avatar
I just saw a new product from Dupli-color for interior and upholstery in a rattle can. They have different colors. I don't now much more than that but the demo was cool.
Old 03-18-2009 | 06:40 AM
Commando's Avatar
I seen the product as well, I have heard that it's great from some of the customers who bought it, but some people don't like the idea of it so they don't buy it and think it's no good.
Old 03-18-2009 | 03:37 PM
69Fury3's Avatar
Iv'e used the black spray dye on vinyl and have no complaints about it.
Old 03-19-2009 | 07:29 PM
Crazy4Carz.Com's Avatar
Go to a GOOD auto paint supplier in you area. Be very nice, and ask for lacquer. It is technically gone but the better shops still have some and will take care of people they like. If you don't know how to spray it ask an old timer they can show you. IT DOESN"T COME OFF.
Old 03-21-2009 | 03:49 PM
roadrun383's Avatar
Junior Member
I would use a dupli-color product make sure you scuff the pieces you are painting with a grey scotch bright, you should be able to pick them up at any parts store. Also make sure you Clean the part good, you could use A wax and grease remover Dupont part number 3901, before and after scuffing, is parts are really dirty you could also use dupont's 3909.
Old 03-22-2009 | 06:42 PM
Oh well, I guess if you don't care if it peels off.
Old 12-27-2009 | 12:44 PM
76_roadrunner's Avatar
I have used Dupli-color upholstery dies (paint) in rattle cans numerous times and I have had no problems. I used it several years ago on my '54 Mercury seats and it never peeled or flaked at all, they still look just like they did when I did it.
This stuff works great and if you follow the directions on the can you to will find that will last.
Old 12-27-2009 | 02:06 PM
old tired rebel's Avatar
I used Krylon before followed the direction on the can. It still came off.
Old 12-27-2009 | 10:37 PM
Krylon makes a great paint if you are doing hobbies and crafts, but I have never had any success with their vinyl paints. Dupli-color vinyl dies and paints are flexible and they expand and contract with the cold and heat.
Old 02-07-2010 | 10:55 AM
mopardrt's Avatar
For my dart I used plastic specical paint from duplicolor sold in all autozones and orileys/murrys worked good so far for my dart i went from green to black and it matched up pretty good with the original black in the car, just make sure you wash the pieces ur painting down real good, then dry paint and repeat p.s all black interior pieces were sprayed sating black by mamopar
Old 02-07-2010 | 02:51 PM
volaredon's Avatar
Member
I have been wondering about this as well; I have a buddy with a 70 Cuda convertible; nice car except all the peeling paint on the interior plastic. If I cant find a factory console for my Volare in the right color I might be forced to dye the one I have. and teh color I need is lighter than the color it is molded in.
Old 02-07-2010 | 04:05 PM
samuelcosmo76's Avatar
i saw an episode of Stacy David's Gears, and he used a 3M adhesion promoter (i think) and vinyl paint. Anyway, its probably worth it to look online for that episode, because it looked really nice when he was done with it.
Old 02-08-2010 | 03:52 PM
Try SEM from Eastwood
Old 02-08-2010 | 04:38 PM
  #24
mopardrt's Avatar
Thumbs up
as long as the part your painting is plastic and you clean it really good then there should be no problem as long as you use a good plastic paint and coat it 2 or 3 times
Old 02-11-2010 | 05:15 PM
  #25
Cracocuda's Avatar
Interior Job
Vinyl Spray Paint and a clean ,clean,clean panel,worked for me.
Old 03-03-2010 | 06:28 PM
  #26
rdrunner1974's Avatar
Go with the Sem and the prep as suggested. I would use rattle can enamel on the metal. I have used vinyl spray on metal and it does not adhere well.
Old 03-03-2010 | 07:21 PM
  #27
Furytom's Avatar
I didnt even think about painting the interior. Thanks guys! All this new options for my interior. Like I could make it black now. Or black. Or maybe even dark black or so.
Thanks for all the great knowledge!
Old 03-03-2010 | 07:44 PM
  #28
Agile's Avatar
Member
OR what you can do is go to a junk yard or something and pick up a dash that is similar and cut it into chunks and try different products and see which one comes out the best before doing your own
rlowe
04-07-2013 05:17 PM
ppbmac
01-01-2011 10:36 PM
mopargtx
02-05-2010 03:33 PM
Titanfang
04-20-2007 09:15 PM
jsolo_357
08-24-2006 06:36 AM
