Koul Tool
1 Attachment(s)
For many of the seasoned rebuilders out there, Koul Tool's product line is probably old news, but for those of you, like me, who are tackling the job
of installing AN fittings upon braided steel hose for the first time... check this tool out! Naturally, creating a clean cut, using the correct hose cutter, makes the job easier to begin with, but having said that, when inserting the hose in AN fittings, you need to get it right, hopefully the first time or you run a risk of fraying the hose end and creating a lot of extra grief for yourself. It took all the pain out of inserting cut ends of braided hose into fittings. As a beginner, I used this tool on over 30 fittings with a zero error rate! Well worth the buy. Summit has em in different kit combos. Check it out! |
I Agree...... It dose work Great..... I'll add the Video for Y'all....
