Mopar Forums (/forums/)
-   Do-It-yourself Section (https://moparforums.com/forums/f6/)
-   -   Mopar high heat paint (https://moparforums.com/forums/f6/mopar-high-heat-paint-595/)
Commando Jan 8, 2008 05:30 PM
Does anyone know of a high heat (1200 degree) Mopar blue spray paint? I have found up to 500 degrees in that color, and only dark blue and sky blue in 1200, thought someone may have found what I am looking for. Thanks
wsalguero99 Mar 6, 2008 03:14 PM
try jegs.com they might have it
Mopar Guy in Delaware Apr 3, 2008 11:17 PM
Not sure how your using this, but power coatings can provide the range and may not change colors from extreme exposure to constant heat. They like heat.
Commando Apr 4, 2008 03:18 AM
Is that the one where they have the four stages, where you prep, paint and coat the block or something like that? I was looking for a higher degree paint just for the block, but I eventually settled on the 500 degree. It turned out well, I will post some pictures of my final project when I get a chance.
Mopar Guy in Delaware Apr 4, 2008 09:12 AM
With the powder coat the whole thing gets baked. Good luck with the 500, should do ok. Hope it never gets that hot.
Commando Apr 4, 2008 07:56 PM
That is my concern, it is an out of body paint, and I put with three coats after I stripped the old paint off. Shouldn't be too bad, probably see something around the headers though.
74chargerse May 9, 2008 11:36 PM
74chargerse May 9, 2008 11:38 PM
powder coating only comes in general colors, Im a painter please trust me as it is also exspensive
Commando May 10, 2008 07:08 AM
I had a set of headers powder coated, cost me $200 or something can't remember, and I think they only used 1200 Deg paint and its coming off. Everytime I go by their shop the open sign is displayed and all the doors are locked, so I can't even find out what they did. I know now to confirm the temperature rating, was told should be 1800 degrees.
challenger Oct 23, 2008 08:37 PM
COME ON ADMINISTRATORS WHERE THE #%&! ARE YOU AND WHY DO YOU WANT THE YOUNG GENERATION THAT WANTS TO COME TO THIS SITE AND GET HELP WOULD YOU WANT THEM TO SEE THIS, I FOR ONE WOULD NOT LET MY YOUNG BOY SEE THIS !!!!!!! GET RIDE OF THIS YOU HAVE THE POWER TO DO SO , SO WHY NOT DO IT ( WHERE IS 1BM AT )
http://www.moparnuts.com/forums/images/smilies/puke.gif
