My dodge dart will not go past 70 mph at about 3000rpms?
Old 08-11-2011 | 07:29 PM
captain america's Avatar
I have a 1972 dodge dart with a 383, the problem is the car runs strong until I hit about 70mph at about 3000rpms. The car wont go and faster then 70mph and starts to sputter down. Does anyone know what this problem could be?
Old 08-11-2011 | 09:29 PM
Check fuel flow, maybe put a new fuel filter in... Check the throttle cable for full travel
Old 08-12-2011 | 12:19 AM
MercuryDon's Avatar
Could be fuel or a week coil. Also bad condenser if you are still running points.
Old 10-04-2011 | 12:31 PM
JS23's Avatar
Will the engine free rev above 3000 in neutral
Possibly valve float if springs are old.
Old 10-04-2011 | 02:33 PM
Welcome to the Captain. All good stuff, some 4 barrel carbs have a secondary "lockout" tied in with the choke mechanism. Easy to check then I'd be looking at fuel starvation. Pulling your plugs and checking the colour might give you your answer too.
Old 10-04-2011 | 04:54 PM
samuelcosmo76's Avatar
If you got the original gas tank, its damn sure the filter! Get a clear one so you can see when it gets clogged! Gas is clear, not brown! :-)
Old 10-12-2011 | 05:49 AM
Thanks guys I ended up replacing the gas tank and fuel filter along with running a new gas line.
moe7404
07-12-2014 04:53 PM
TVLynn
10-06-2013 07:25 AM
stuntly69
10-31-2012 09:00 AM
lilredex
08-02-2012 02:04 AM
Commando
09-07-2010 09:42 AM
Quick Reply: My dodge dart will not go past 70 mph at about 3000rpms?
