Mopar Forums (/forums/)
-   Do-It-yourself Section (https://moparforums.com/forums/f6/)
-   -   Need a brake booster for my 1973 fury suburban wagon (https://moparforums.com/forums/f6/need-brake-booster-my-1973-fury-suburban-wagon-6391/)
dz! Jun 1, 2010 05:03 PM
Hello. Looking for a used or alternative brake booster for my wagon. Not sure this is the right section of the forum or not? My booster is completely shot, doesn't work at all and is causing a vacuum leak. I just installed new front calipers, rebuilt master cylinder, new front brake pads. Looking for an alternative that I could possibly pull out of a junkyard car. Just got the wagon running and want to take it for a drive to see if it needs anything else before it goes for the safety inspection. Drove it around the yard with no power booster and it's a bear to try and stop all that car with no assist. Thanks in advance.
Sgt. Veteran Jun 1, 2010 05:10 PM
No fun with no booster is it lol, I dont know off the top what else would work but in such case you have to remember they prob. used that booster on a few diffrent cars so if you can find a part number on it or do some searching on line for a part number you can see what else came with it and narrow down your search in the scrap yard, other then that no idea sorry
scott2683 Jun 1, 2010 05:11 PM
I have a 64 880 and I had to send my booster in and have it rebuilt. Napa was the fastest return. Good luck to you!
Sgt. Veteran Jun 1, 2010 05:12 PM
expensive scott?
