Mopar Forums (/forums/)
-   Do-It-yourself Section (https://moparforums.com/forums/f6/)
-   -   No Brake Lights (https://moparforums.com/forums/f6/no-brake-lights-3119/)
roadrun383 May 23, 2009 06:39 AM
No Brake Lights
They were working last time i drove the car, The blinkers and tail lights work, the brake switch is working, does any one have any ideas??
chlngr1970 May 23, 2009 10:26 AM
Fuses, or the bulbs are corroded into the socket. I had the same problem on my truck. It magically happened after I brought home two big blocks and transmissions:D
Those would be where I would look.
j
blue 68 gts May 23, 2009 10:56 AM
j
Those are the two things that popped into my head when I first read this..
Also, the bulbs may be broken. Start by checking the bulbs, and tracking it down.
-nick
richinny May 23, 2009 02:26 PM
signals and brake lights are the same filament so wiring, sockets, bulbs etc are all ok.
it could be a bad turn signal switch, you'll have to trace the power in and out. also, try changing the position of the 4 way flasher if you have one.
roadrun383 May 23, 2009 05:17 PM
richinny what do you mean try changing the position of the 4 way flasher, do you mean plug the connector in a different way
richinny May 24, 2009 10:10 AM
change the switch position.
btw, what year is your car?
roadrun383 May 24, 2009 09:44 PM
its a 69, still no luck with it
scotts74birds May 24, 2009 10:57 PM
http://www.mymopar.com/downloads/1969/69BelvedereGTXSatelliteRoadRunnerA.JPG
scotts74birds May 24, 2009 10:59 PM
K, here's a starting poiint. Where does the power stop. With this you will be ok, gert in touch if there is still a problem. Good luck buddy
78D200 May 25, 2009 12:06 AM
no grounding wire or the signal from teh brake switch is not making it all the way to the back.
richinny May 25, 2009 06:41 AM
as mentioned, you have to trace the power from the brake switch. since the power is getting to the back you seem to have an open wire between the brake switch and the turn signal switch. check those connectors with a test light to see if the power for the brakes goes in and out of the turn signal switch. check for corrosion in the turn signal switch plug. i think 69 had the 4 way flasher switch on the dash? if so, check that connection too.
scotts74birds May 26, 2009 08:09 PM
Things get a little goofy on these cars. Since the brake and turn share the same lamps, the turn flashes when the brakes are off, but must interrupt the brakes when they are on. Richinnys sharp, listen to him
roadrun383 May 26, 2009 08:52 PM
thanks for the help have been busy with work, will check tomorrow everything tomorrow, i do have another question though, if i replaced the blinker switch, does it matter what wire i hook up, the instructions did not say.
scotts74birds May 26, 2009 10:23 PM
Sorry, I'm into the sauce now. No more advice tonight! I'm laid off, try you tomorrow, after noon. hic..... hic....I love you man!
richinny May 26, 2009 10:37 PM
"blinker switch"?
do you mean brake switch or turn signal switch?
brake switch = no
turn signal switch = yes
scotts74birds May 26, 2009 10:52 PM
Checked the blinker fluid yet?.............hic........
roadrun383 May 28, 2009 05:15 PM
alright thanks ill check and see if i hooked the blinker switch up wrong.
roadrun383 Jun 1, 2009 07:11 PM
got them fixed thanks for all of your input
scotts74birds Jun 1, 2009 07:20 PM
So, what was it? This is how we all learn.
