performance 318
Old Jun 6, 2011 | 07:16 PM
bandrew9's Avatar
performance 318
i have a 95 ram with 318. automatic. Im looking to put some performance parts into it but having some trouble finding parts. i have checked edelbrock and summit. anyone know a place that sells good parts for minimum budget. I live in Indiana
Old Jun 6, 2011 | 08:46 PM
78doubleR's Avatar
Just search summit for the motor. The aftermaket for these trucks is pretty big. You can get ecus, cams/lifter, headers, heads, cai, etc, etc. summit has all of it too.
Old Jun 7, 2011 | 01:31 PM
Look here. http://www.hughesengines.com/Index/index.php
Old Jun 7, 2011 | 03:31 PM
78doubleR's Avatar
^^ YES!! Hughes is also another great source.
Old Sep 12, 2011 | 06:47 AM
cudaracer's Avatar
I am calculating my CR for my stock 318, and something don't add up because I am getting a 9.2:1
I doubled checked all my parameters from this site,
http://victorylibrary.com/mopar/deck-height.htm
…and yet the math shows the block deck to piston distance of about zero, yet most claim the pistons should be in the bore by about 0.050"
Here is my math,
deck height - half stroke - rod - piston height =
= 9.6" - 3.31" / 2 - 6.123" - 1.822" = ZERO
How is the rest of the world getting a recessed piston of about 0.050"
Anyway, when I plug it in with a 63cc chamber volume, my CR = 9.2:1
WTF???
Anybody?
Old Sep 12, 2011 | 02:25 PM
If we're talking 318's most stock piston compression heights are 1.74" - 1.79"
Old Sep 12, 2011 | 07:01 PM
cudaracer's Avatar
Really?
So that website is far off then.
Old Sep 13, 2011 | 04:42 AM
Just looked at that site and it says "max compression height" so they probably just did the math and came up with that number.
Old Sep 13, 2011 | 01:16 PM
cudaracer's Avatar
thanks for the information.
When I plugged in the 1.77" compression height, I got the following CR values...
Stock 318 block with 302 heads (62.6cc) with 0.080" gasket and = 8.56:1
Stock 318 block with 340 "X" heads (71cc) and 0.020" think gasket = 8.55:1
Stock 318 block with 340 "X" heads (71cc) decked and 0.020" think gasket = 9.3:1
Does this coincide with popular wisdom, because it makes no sense for me NOT to use the X heads on my 318. I ran several cam scenarios through CamQuest6 and everything tells me to use them. I even bored the 318 0.050" and the hp barely budged, so it makes no sense for me to go that route.
I should have a screamer in the 5K rpm range, with only heads, cam, intake, headers and carb. All I need is a cam.
Any experiences out there to the contrary?
thanks again
68Dart
Mar 17, 2019 05:43 PM
lostfish
Apr 14, 2011 11:05 AM
Valex9499
Nov 20, 2009 04:03 AM
mike639
May 28, 2009 06:58 AM
lostfish
Nov 26, 2007 02:54 PM
