Radiator Hose inner coil
Old 04-09-2014 | 08:05 PM
mrzods13's Avatar
i bought galvanized steel 14 gauge wire from lowes and made the coils myself, anyone think these will be a problem, a little thicker than than old ones not by much if it is not strong enough any suggestions on what to use
Old 04-10-2014 | 04:19 AM
Mr.4spd's Avatar
I use one of those ribbed universal hoses for my lower location. Very strong, and no internal coil to rot out...it is ugly though.
Old 04-10-2014 | 07:09 AM
mrzods13's Avatar
The old coil I took out was just starting to show a little rust after 40 years, not too bad I guess, I am a little iffy about the wire it is thicker but just seems softer than the original.
Old 04-10-2014 | 02:40 PM
Hate to suck it into the cooling system
Old 04-10-2014 | 02:59 PM
pro-tech's Avatar
The coil in the lower hose is spring steel made of stainless steel I would not use wire..Reuse the old spring/coil and put it into the new hose...Why don't they come with the coil in them anymore???? Bill
Old 04-10-2014 | 07:07 PM
mrzods13's Avatar
Ok problem solve stupid me forgot flex hose has the spring, bought it for $10 cut the hose open took the spring put it in the A/C Coolant hose. Fits perfect and the length is exact. Needed the ac hose because I upgraded to a 26" radiator.
Old 04-11-2014 | 07:11 AM
pro-tech's Avatar
Originally Posted by moparted
because its not needed
Why isn't it needed??? You put these comments in like you are some kind of wizard or something...I guess they put them in there because they had a whole bunch of left over Slinkys that they needed to get rid of...And those stupid engineers what the hell do they know...If you take the coil out of the lower hose when the RPMs increase the lower hose will collapse and restrict the flow of coolant causing the engine to run hot and or overheat.. Unless you are Joe cob job and use a universal flex hose which looks like chit...
LaurenMagnum360
02-08-2014 08:08 PM
olibass1
04-04-2012 12:06 PM
Halibrand
02-20-2010 05:32 PM
beep1969
12-24-2009 11:17 AM
67Polara
08-08-2009 05:18 AM
Quick Reply: Radiator Hose inner coil
