Mopar Forums (/forums/)
-   Do-It-yourself Section (https://moparforums.com/forums/f6/)
-   -   rocker ratio (https://moparforums.com/forums/f6/rocker-ratio-10321/)
madman23420 Aug 8, 2011 11:07 AM
rocker ratio
i am almost finished building my 318 for my truck i would like to possibly get some adjustable roller rockers later on maybe with a 1.6 ratio instead of the stock 1.5 i have a small rv cam with a .40 over block and j heads is there anything else i will need to do before swapping rockers like a stall converter because of more valve lift from a different ratio or would it just be better to stick with a 1.5 ratio rocker also has they say clearance may be an issue what might i have to have machined to get the adjustable rollers to work i know i have to get new pushrods and i already have hp valve springs i just want to know what im getting myself in for.
