Mopar Forums (/forums/)
-   Do-It-yourself Section (https://moparforums.com/forums/f6/)
-   -   Window out of alignment on 72 Duster (https://moparforums.com/forums/f6/window-out-alignment-72-duster-12267/)
DusterDude88 Apr 30, 2012 05:10 PM
I noticed last night after cruising around in my 1972 Plymouth Duster that when I went to roll my drivers side window up, it was extremely hard to roll the window up. I rolled it up as far as I could and shut the door, only to see that the rear of the window, on end with door handle, lacked 1.5 to 2 inches of completely being rolled up.
So clearly, I'm sure that there's a misalignment somewhere but I just don't know what to do to correct it. I tried adjusting the division track by turning the bolts on the bottom of the door and had little luck but not much and the window is still hard to roll up and down.
What would be the correct method to correct the misaligned window? Any help would be greatly appreciated, I've only worked with one other jammed window and it ended up getting broke(it was in a mack truck though so no major loss) but I dont want to break my window.
Any help would be greatly appreciated!
Thanks,
Jon Preston
TVLynn Apr 30, 2012 07:27 PM
It is more than an adjustment.. Take the door panel off, maybe one of the plastic clips for the4 window regulator arm broke ??
MrOldart2U Apr 30, 2012 08:05 PM
yeah sounds like a roller issue to me also. You will need to remove the door panel to access...
