wiring harness change.....?
ok i want to change my dash in my 69 dart gt i want to go with either newer style gauges or maybe even digital how much of the wiring would i need to change to make this work? i am thinking it would not be a hard switch am i fooling myself or what?
it's not as bad as you would think if you can handle wiring and have patience. if using the existing harness, make sure the wires you use are for their intended purpose.
there isn't much to wire up - hot and grounds for everything, dimmable lighting, and the sending unit wires.
