06 Chrysler Sebring 6 cylinder
Today I was sitting at a red light, and my sebring just losses all power, so I'm stuck in the intersection.well we got it off the road got it towed home, I changed the map sensor and now it turns over but still will not start, any suggestions?https://cimg8.ibsrv.net/gimg/moparfo...241ca272af.jpg
https://cimg2.ibsrv.net/gimg/moparfo...43a41e211c.jpg |
Check the fuel pressure and see if it needs a fuel filter change?
Thanks I'll give that a shot
(Post 145897)
All power as in dead battery or no power as in will not run?
(Post 145906)
Alternator good Stopped at red light, light turned green and the car loss power slowly till nothing Now it cranks over, but nothing |
Again - lost electrical power? As in lights went dead
or engine power as in motor was not running good enough to pull the car five feet . With all your new parts you have had electrical problems? if you want help you need to be as precise with your descriptions as possible so the reply can be on track. Thanks |
(Post 145911)
