Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   1977 440bb heats up on highway (https://moparforums.com/forums/f62/1977-440bb-heats-up-highway-18812/)
Flame Aug 11, 2015 11:25 AM
My girl stays right about at 190 unless I go over 50mph (2700rpm or so) on a warm day. What's your temp on the highway? Is it normal for it to get up over 215? Is it the radical cam? Timing? Running your standard antifreeze and water.
TVLynn Aug 11, 2015 01:39 PM
What kind of radiator ? Compression ratio ? Water pump pulleys ? thermostat ? Rad shroud ? Gear ratio... all can cause heating
Magoo Aug 12, 2015 11:55 AM
See "408 Gets Hot In Traffic" -- below in this section
-- See discussion re "408 Gets Hot In Traffic" in this section, for some input on a similar situation. -- Good Luck.
