1994 dodge ram 1500 code 37
I am receiving a code 37 on my truck and it wont start. What do I need to look for
A quick search on Google pooped up these:
-transmission teperature sensor -trans temp sensor voltage too low -trans temp sensor voltage too hi -torq conv clu, no rpm drop at lock-up -torque cinv clutch solenoid CKT -P/N switch stuck in PARK or in gear -relationship between engine speed and vehicle speed indicates no torque converter clutch engagement -an open or shorted condition detected in the torque converter part throttle unlock solenoid control circuit -park/neutral switch performance |
Is it cranking and not starting or not doing anything?
Its turning over but not firing I do have a new coil. Im also receiving code 11 and 37
| All times are GMT -7. The time now is 03:58 AM. |
