Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   340 Intake On 318 LA (https://moparforums.com/forums/f62/340-intake-318-la-25343/)
Carter_8147S_Hater Jan 24, 2024 07:36 AM
I have come into possession of a 340 intake with a weber carb on it. I have a 1977 Dodge D100 and I had the truck running after it sat in a field for 11 years but it started to knock and consume oil at an incredible amount so I decided to pull the engine and rebuild it. As I said above I have a 340 intake and I'm wondering if that 340 intake will match up to my 318 2 barrel. I'm trying to make this truck fun for as cheap as I can so if I can avoid buying a new intake that would be awesome. I was told the 340 intake was from the early 70's (I know it's kind of broad, I should have asked for more info but I didn't.) Any help is appreciated greatly.
Iowan Jan 24, 2024 09:45 AM
It wil work but the intake has larger ports than the 318 heads, do you have a photo of the intake?
Skwerly Jan 27, 2024 11:11 AM
i believe most the aftermarket intakes say 318/340/360, so while it might not be a scientific fit, it'll defintely do the job and well! i think youre fine, bud. :)
Carter_8147S_Hater Jan 30, 2024 02:33 PM
Sorry it took me a while to get pics. Here ya go
https://cimg4.ibsrv.net/gimg/moparfo...830765672.jpeg
https://cimg7.ibsrv.net/gimg/moparfo...2456ae129.jpeg
https://cimg8.ibsrv.net/gimg/moparfo...f79821371.jpeg
Carter_8147S_Hater Jan 30, 2024 02:36 PM
That’s what I figured but I thought I’d ask before I reassembled the engine. I’m not looking for a crazy perfect drag engine, just something that’s tastefully loud and has enough gumption to it to outrun a mail truck.
Iowan Jan 31, 2024 07:08 AM
The aftermarket versions fit the 318 but with a little grinding can be opened up to the 340/360 ports.
Skwerly Jan 31, 2024 10:46 AM
yes yes, your setup is perfect! run it and go! :D
