340 stroker kit questons??
So I have been doing some research for my 340 and its going well. But like always, I want your guys input as you have never took me down the wrong path!
Looking into doing a stroker kit on the 340. I think I want to go with the SCAT stroker kit but I want another opinion! Looking to go for the 408/416 Thinking 1.6:1 roller rockers? Anyone using these and are they good or bad Any ideas about this kit/ better kits to buy? Wanna make about 500 h.p out of this puppy and need some more well rounded guidance. Also should I go with a Forged crank or stick with cast? Then its onto pistons...Flat top? I know this is alot to ask, but just got a new motor to play with and I have never fully built a engine. Thanks guys~ Sean:clap: |
HP is in the cam and heads.Torque is in the stroke. What is this engine going to do? Scream at high RPM or grunt out stump pulling torque at 1800?
I would go with this forged internally balanced Callies stroker kit from Mancini.
http://chucker54.stores.yahoo.net/340focrinbaa.html |
500 hp! don't even think about a cast crank. The Mancini kit is a proven combo. along with a 7-8 qt Milidon oil pan Some ARP main studs maybe a windage tray You may need to shim it away from the crank for the stroker clearance
1 Attachment(s)
@bigblock
I want to get the horsepower at the mid to top end. @TVLynn @Bremereric I will definitely look into the Mancini kit and thanks for the advice! Here is the new canvas, 1971 engine with J heads Attachment 13831 |
Do I have to do a stroker kit to make the kind of power I am looking for??
