Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   360 idles smooth then i put in gear it stalls?!?!?! (https://moparforums.com/forums/f62/360-idles-smooth-then-i-put-gear-stalls-10737/)
northcoasttip Sep 28, 2011 12:15 PM
My 360 was running ok when i first got it,now when its running and i go to put it in either drive or reverse it stalls! any suggestions
76 Doba Sep 28, 2011 01:31 PM
I'm just going to guess it is a mid 70s model. I'd like to hear suggestions on this as well.
Archer Sep 28, 2011 03:30 PM
north -
First guess would be to look for a vacuum leak. Then timing (less likely), then make sure your carb's circuits are clear.
northcoasttip Sep 28, 2011 03:47 PM
you know what,you hit it dead on the head,i just remember when i was doing the timing i forgot to hook the vac advance up,and some other ones! smh thank you
Archer Sep 28, 2011 07:21 PM
north -
Every once in a while I make a lucky guess ;)
Glad it was that simple!
northcoasttip Sep 29, 2011 03:00 PM
thats crazy though because i had just did the timing,was happy it was running good and for got the vacs! LOL thanks alot
