4.7 timing cover leak?
Old May 4, 2010 | 02:47 PM
johnthegoalie's Avatar
thinkin with me dipstick
after months of smelling antifreeze when the truck was hot with no fluid loss, finally a few weeks ago found a puddle of antifreeze under the truck from under the water pump. changed the pump and no more puddles or smell but...
over the past few days i've noticed along the bottom of the timing cover where it mates to the block there is a slight seepage of antifreeze. over a few day span it is not enough to drip, but enough to accumulate slightly and jelly over. today, i was able to tighten the timing cover bolts a little and i'm hoping this solves it. how common is a leak from the timing cover?
Old May 4, 2010 | 03:17 PM
1966sportfury's Avatar
A.K.A Bob Dodge
i cant answer your question. but thanks for bringing that up..so i know what to look for if it happens to me.
Old May 4, 2010 | 05:30 PM
i finally got under the truck enough to see what is seeping and what isn't. the two areas coincide with the two water passage o-rings. i am going to see if i can get the surrounding bolts a little tighter as i really don't want to take the front of the enigne apart.
Old May 4, 2010 | 06:33 PM
67gtxclone's Avatar
I don't blame you for not wanting to take the front apart. That is always a pain and takes longer than you think it would.
Old May 4, 2010 | 09:53 PM
i waited until the truck cooled off completely and was able to get the bolts above and below the passage tightened just a little bit. hoping thats enough...
Old May 4, 2010 | 10:15 PM
A.K.A Bob Dodge
kool hope it works....
Gorts 5th
Dec 19, 2012 04:52 PM
dnlwstwd
Oct 12, 2011 08:08 AM
teedeej340
Dec 1, 2010 06:16 PM
dtanner
Apr 21, 2010 07:17 PM
recondotexas
Apr 3, 2010 03:44 PM
