Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   440 Approx Value?? (https://moparforums.com/forums/f62/440-approx-value-11382/)
tbakko Jan 5, 2012 11:43 AM
440 Approx Value??
I am putting togeather my 1978 440-4 to sell. It came out of a motorhome with approx 38K miles. The motor had virtually no wear on it, so I took it to the machine shop & had it hot tanked, machine honed & cleaned, then I had the crank checked for wear & polished. I put in new main bearings, rod bearings & rings. Valves were lapped & the engine is being put back togeather with all new seals. I installed an Edelbrock performer cam & lifter set and a true roller timing set. I don't have the exhaust manifolds, carb, water pump or other appurtenance. I am trying to get an approximate value on this motor. Thanks, Tom
bremereric Jan 5, 2012 12:03 PM
Start off with 200 bucks for the core and add what the machine shop charged and what you have spent so far.
TVLynn Jan 5, 2012 01:12 PM
Maybe 12 years ago I sold a 440 125K miles, all apart but cleaned. NO new parts for $750
