440 external oil pump modification
Old Jun 16, 2009 | 04:43 AM
fastdakota84's Avatar
Hey,
I'm new to this forum, and I had a question about modifying the the external oil pump for a 440. Is it possible to modify the pump to accept an external oil line from a pick up in the pan if you block off the internal line, redrill and tap into the oil pump hole on the pump, fitting the appropriate line fittings. Does this present a problem?
Thanks Guys ahead of time!
Old Jun 16, 2009 | 05:30 AM
Polaradude's Avatar
Welcome to the forum man.
I would say your easiest route and probably safest is change the oil pan and then run what ya want.
Old Jun 16, 2009 | 07:45 AM
2x on what polara said
Old Jun 16, 2009 | 09:51 AM
What do you mean by change the oil pan? The reason I was looking at doing this is to setup and external oil system on my 440. I am putting this 440 in my Dakota, and had to put a notch in the oil pan to clear the cross member. Being that, I have to extend out the oil pickup to clear the notch. When I extend the pickup, it causes possible issues with clearance. That is why I mention to go with the external oiling system, is to totally get rid of the internal pickup setup, plus I am on a budget. I know how the systems can get pricy!
Old Jun 16, 2009 | 03:31 PM
Yea, that is what I thought with using a flexible line. I knew with the internal pressures and the oil breaking down the rubber, that it probably would not be a good idea to use a hose inside the oil pan. I figured if I was going to do it, I might as well do an external line with better oil flow than the more restrictive internal pipe. So you don't think it is feasible to modify the pump?
Old Jun 16, 2009 | 08:04 PM
theomahamoparguy's Avatar
yes you can run an "External Line" straight off of the oil pump housing {special cover made by Milodon and others} and route it into the oil pan through a fitting mounted into the oil pan wall. You can use steel braided line or hard line. On the inside of the oil pan where the fitting goes through you can mount the pickup. They even have one that "swings" for the oil accumilation caused by the inertia of the car as it launches. You can run one line or two. One is good for the street. Yes the original threaded hole for the original pickup will need to be plugged {easy to get pipe plug}
BTW, this is one of the adv antages of the big block mopars (hemi's too)'
you can put the oil pickup where you want it {within reason} because the oil pump is mounted on the outside of the block.
Old Jun 17, 2009 | 10:10 AM
Sorry, what I meant to say was can you modify the stock pump by drilling and tapping a new hole. That way you could save $ by not having to buy the whole oil system setup. I know it can be pretty expensive specially when your on a budget. Basically, what is the difference betweent the Milodon pump cover with external line provisions and modifying a stock pump cover to except external lines? I know as mentioned above that there might not be enough room to tapp that big of a hole, and you might be right. Something I'd have to look in to. Thanks for your help guys!
Old Jun 17, 2009 | 01:54 PM
lets us know how it turns out
Seanzie1405
Aug 27, 2013 12:09 PM
koterkid
May 26, 2013 09:49 AM
darrell90712
Jun 7, 2011 02:59 PM
Henrius
Nov 13, 2009 12:36 AM
dzltd02
Oct 28, 2008 08:25 AM
