440 tune up used in 1959 F-250 3/4 Ton
Old Oct 27, 2010 | 10:14 AM
auerdoan's Avatar
Thumbs up 440 tune up used in 1959 F-250 3/4 Ton
i recently bought a 1959 F-250 3/4 ton
it came with a 440 engine with 440 header and a 727 tranny.
i have a repair manual but its mainly a rebuilding overhaul type of book
i would like to do a tune up on this engine.
but lack the specifics for this
can some one post the basic parameter for this
spark plug gap
are the valves self adjusting if not the gap
spark plug order
Degrees of Top dead center at idle when i use th timing light.
anything else i might need or missed
thanks for any help
if you need more details just let me know
i look forward to working with you guys.
Auerdoan
Old Oct 27, 2010 | 12:05 PM
1966sportfury's Avatar
A.K.A Bob Dodge
1-8-4-3-6-5-7-2 firing order
.035 gap for electronic ignition
valves are non adjustable
around 8 btdc that should get it running then tune buy ear,
what yr is the engine? well if its in a 1959 or a f-250 its not stock,
Old Oct 27, 2010 | 01:03 PM
auerdoan's Avatar
This is what i found on my engine sorry i had a tough time finding the year i believe its between 75 -79.
the transmission its a a727b with these numbers 6A162543
the engine is a 4006630-44-9 with these numbers 7-72-75 I think I copied the number wrong if this is a date code it maybe 7-12-75
Old Oct 27, 2010 | 06:40 PM
rr69half6bbl's Avatar
what you have is an early production 76 440. and trans, the 6-a # on the trans means 76. the a measn the assembly plant which was lynch road. the block was cast sept. 15th of 75 and usually the build time between casting and production was 3-4 weeks.I concur w/ all 66 furys info for your tune up.
Old Oct 28, 2010 | 10:06 AM
auerdoan's Avatar
Thanks alot guys! this will help me save money doing it myself.
a tremendous help!
if there were a car that might be similar and i was referring to a repair manual
what might it be--im wondering if this is in my face (66fury)
i understand teh weight may be different
hmm mine is 3500 lb
Old Oct 29, 2010 | 09:41 AM
auerdoan's Avatar
i forgot to ask what spark plugs i would need
thats why a repair manual would be so useful
Old Oct 29, 2010 | 12:27 PM
A.K.A Bob Dodge
im a autolite guy, plug # 85
Old Oct 29, 2010 | 09:40 PM
auerdoan's Avatar
Thanks Fury anything goto be better than what i have in there
fawazoil
Apr 21, 2008 05:44 PM
