440 tune up used in 1959 F-250 3/4 Ton
i recently bought a 1959 F-250 3/4 ton
it came with a 440 engine with 440 header and a 727 tranny. i have a repair manual but its mainly a rebuilding overhaul type of book i would like to do a tune up on this engine. but lack the specifics for this can some one post the basic parameter for this spark plug gap are the valves self adjusting if not the gap spark plug order Degrees of Top dead center at idle when i use th timing light. anything else i might need or missed thanks for any help if you need more details just let me know i look forward to working with you guys. Auerdoan |
1-8-4-3-6-5-7-2 firing order
.035 gap for electronic ignition valves are non adjustable around 8 btdc that should get it running then tune buy ear, what yr is the engine? well if its in a 1959 or a f-250 its not stock, |
This is what i found on my engine sorry i had a tough time finding the year i believe its between 75 -79.
the transmission its a a727b with these numbers 6A162543 the engine is a 4006630-44-9 with these numbers 7-72-75 I think I copied the number wrong if this is a date code it maybe 7-12-75 |
what you have is an early production 76 440. and trans, the 6-a # on the trans means 76. the a measn the assembly plant which was lynch road. the block was cast sept. 15th of 75 and usually the build time between casting and production was 3-4 weeks.I concur w/ all 66 furys info for your tune up.
Thanks alot guys! this will help me save money doing it myself.
a tremendous help! if there were a car that might be similar and i was referring to a repair manual what might it be--im wondering if this is in my face (66fury) i understand teh weight may be different hmm mine is 3500 lb |
i forgot to ask what spark plugs i would need
thats why a repair manual would be so useful |
im a autolite guy, plug # 85
(Post 57645)
| All times are GMT -7. The time now is 04:39 AM. |
