Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   5.7 hemi torq specs (https://moparforums.com/forums/f62/5-7-hemi-torq-specs-6188/)
smackhonda May 13, 2010 08:22 PM
5.7 hemi torq specs
any one know the torq specs for the cylinder head and intake manifold for a 5.7 hemi off the top of your head?
sweeperking May 14, 2010 04:35 AM
On my 2006 5.7 hemi.......
Intake bolts are 105inch lbs, start from the middle bolts towards the outside in a criss cross pattern
Head bolts are done in either two steps or three depending on the size of the bolt.
and because mine are metric.....
For M-12 bolts Step one is 25Ft lbs
Step two is 40 Ft lbs
Step three Turn 90* (deg)
For M-8 bolts Step one is 15Ft lbs
Step two is 25Ft lbs
This should work for newer model years as long as yours is NOT pre 1980 I can look up your spec if you give me a year.
smackhonda May 14, 2010 04:56 AM
thanks man. I got a 06 hemi so that should work fine. also it doesnt look like there is any adjustment for the valve lash on these rocker arms, are they just pre set. thanks again
sweeperking May 14, 2010 07:01 AM
Rocker arm bolts are 195 in lbs
Throttle body to intake mount bolts are 105 in lbs
Hope this helps
Bing May 5, 2017 08:03 PM
Hello Fella's does anyone have the torque specs for a 2010 5.7 hemi head? I'm in the middle of a head job and could use them. Thanks in advance...
