69' Roadrunner headlamps
Anybody know where I could find the headlights for a 69? I'm not talking about the bezel or the actual bulb, I'm talking about the actual glass/plastic lamp itself that screws in. I've looked online and can't find anything.
the headlight bulb number is h5001 or h5006 depending on if you want the high or low beams. if you are running an ater market set up i know there are a few companies on line that sell the hosuings to convert over to the h7 or 9006/9005 lighting system.
You should be able to buy these, at least halogen replacements if not original type sealed beams, at ANY decent auto parts store. ANY automobile or truck which used round 4-lamp system sealed beams used these lamps.
The original numbers are 4000 (low beam) and 4001 (high beam) Modern halogen replacements sometimes just add an H, or use the 5K series numbers posted above. |
Originally Posted by mikerp76
(Post 85796)
Originally Posted by Nightmare
(Post 85815)
Thanks. I see the h5001 and h5006, it says that they can both be used as highs or low and the descriptions are the same except the 5006 costs a lil more. Is there a difference between the two?
The low beam lamps have 2 filaments, the high beams only one
On low beam, ONLY the low beam filaments in the outer lamps are lit On high beam, the low beam filament is turned off, and.......... BOTH inner and outer lamps light the high beam filaments The lamps ARE NOT interchangeable |
| All times are GMT -7. The time now is 03:33 AM. |
