727 rebuild
Old Jun 8, 2013 | 06:29 PM
440 aspen's Avatar
727 rebuild
Can anyone recomend a good book on rebuilding a 727? I have never rebuilt a transmission before and from what ive heard these 727s arent too hard to do even for first timers. Any suggestions would be appreiciated
Old Jun 8, 2013 | 07:55 PM
moe7404's Avatar
i am NOT an trans expert. but a guy i know that does this told me to put the the clutch plates in trans fulid over nite. and set the pack clearance to the min demtion. if range of Ciearance is .100 to .120 in set at .100. thats not a useable dim. NOTE: iam not a trans expert.
Old Jun 8, 2013 | 09:59 PM
Torqueflite A-727 Transmission Handbook HP1399: How to Rebuild or Modify Chrysler's A-727 Torqueflite for All Applications: Amazon.ca: Carl Munroe: Books Torqueflite A-727 Transmission Handbook HP1399: How to Rebuild or Modify Chrysler's A-727 Torqueflite for All Applications: Amazon.ca: Carl Munroe: Books
#_
Old Jun 8, 2013 | 11:04 PM
Buffalojoe426's Avatar
x2
Old Jun 9, 2013 | 12:15 AM
727 is a very good trans. Not too hard to rebuild. Every thing needs to be cleaned very good. The only problem you will encounter is you need a bushing driver, also need a press to take the clutch pack apart. I would try the local trans shop to do it for you. It is under a lot of pressure and you don't want to loose a finger or two
Old Jun 9, 2013 | 06:59 AM
This can help too:
Old Jun 9, 2013 | 10:01 AM
Good answers. I believe there are 19 or 20 videos with the link posted. I'm sure there are other ways, but I use Firefox, with the "video download helper" plug in. This allows you to save Youtube videos. I have all of these videos saved to hard drive.
DEFINATELY get the Munroe book
Also, there is an extensive section right in the shop manuals, and MyMopar has the transmission service section as a separate download
http://www.mymopar.com/index.php?pid=22
The latest factory shop manual I'm aware of for download is a '72 posted by AbodyJoe over at FABO:
http://www.abodyjoe.com/pictures/Mis...Serv%20Man.pdf
Last, an ASTG manual might be of some help.
https://www.atsg.us/atsg/
Look around on their prices. I bought mine off the website, and found later I could have done better on eBay.
Old Jun 9, 2013 | 11:44 AM
Entropy's Avatar
The 727 really is an easy trans to do, as a kid of 19 I fried one in a 70 Cuda I have. With out the funds to pay someone to rebuild it for me I did a little research down to the transmission guy at my local Plymouth Dealer (no internet in those days). He suggested the B&M trans rebuild kit as it comes with everything you need and a step by step book that even the 727 book for dummys could do no better! The kit goes through the pump to increase fluid flow and goes through the valve body with your pick of how it shifts; soft, hard or neck snapping! That tranny is still in the car and aside from replacing bands and clutch friction plates when they wear out that tranny still churps in 2nd and 3rd gears when ever I get on it. I would say the B&M trans kit is well worth the money and the experience you get from going though the whole 727 will be in valuable down the road.
tc Entropy
MrMopowered
May 9, 2009 11:31 AM
Commando
Jan 1, 2009 10:29 AM
chargerfast1
Nov 6, 2008 05:36 PM
hubcap
May 6, 2008 06:26 PM
ucfierocharger
Aug 4, 2007 07:37 PM
