Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   727 torque flite transmission (https://moparforums.com/forums/f62/727-torque-flite-transmission-10192/)
Coronet Tom Jul 24, 2011 11:43 AM
I have a leak in the plug/fitting at the front of the transmission above the cooling line . When I attempt to remove the fitting/plug I am unable to get it loosened , however when I loosened the 3/4 outer fitting it seems like it may be a locking device and the square plug/fitting is an adjustment . I am afraid to remove it and may have already changed the adjustment ...any suggestions about what may be happening here would be appreciated . I want to teflon the threads to stop the leak .
Coronet 500 Jul 24, 2011 01:34 PM
That is the kickdown band adjustment. Tighten the inner "bolt" to 72 in lbs then back out 2-2 1/2 turns and tighten outer "nut" to 30 in lbs. The amount of back out will vary based on year and vehicle so the proper manual should be referenced. There is no seal on the adjusting screw but you can put a dab of silcone under the locking nut.
Coronet Tom Jul 25, 2011 10:27 AM
many thanks
Hi Coronet 500
thanks for the information , another question ..any idea how to get a free manual for the torque flite 727 transmission?
Tom
John Van Jul 25, 2011 11:22 AM
Tom,here's a good post about the 727 tranny:
http://www.allpar.com/mopar/transmis...-tom-hand.html
john
Coronet 500 Jul 25, 2011 06:01 PM
Well I don't know about free but HP Books has a good one by Carl H. Munroe. The band adjustment should be in just about any vehicle specific manual.
This is how it is suppose to work, a guy asks a question a guy gets an answer.
Some of those Furd forums I look at for my son you ask then get "why do you want
to do that bla bla bla". Mopar guys are the best, keep asking someone will give you
a prompt correct answer without all the B.S..
bobbyd173rd Jan 26, 2012 08:50 AM
What do you guys think of the tci super street fighter tranny
TVLynn Jan 26, 2012 01:09 PM
Depending on how much you turned it ? If you have any problems adjusting it ? You may have to remove the pan. It is possible for the strut to fall out of position
