74 Charger: Are bench seat and bucket seat brackets the same?
3 Attachment(s)
I am doing a bench to bucket seat conversion in my 1974 Charger. I bought some buckets on CL last night and I want to test fit them. I noticed some of the studs on the buckets are cut/destroyed and need to be replaced. Are the outer brackets on the bench seat interchangeable with the outer brackets of the bucket seats? That would be too easy. How do I remove the old stud and replace it. Worse case scenario is I grind it off and drill it out and just use a bolt/washer/nut. TY.
Sounds like a good plan of attack to me.... show us some pictures as you make progress....
:hello: |
ONLY the driver's side. No provisions for the adjuster on the passenger side. Just make sure to use grade 8 hardware
