8 3/4 Axle Installation
I recently built an 8 3/4 rearend for a 71 Duster and purchased a bare housing. I have never worked with axles before and was wondering what parts I would need in order to install axles. I was also planning on using green bearings. What's the difference and how would this change the setup for the axles? I know one side is adjustable when stock so would this still remain? If anyone could point me in the right direction I would appreciate it. Thank you.
well the green bearings make the job alot easier because they do away with the adjustment. you just slide them in and bolt them down.
the bad pard is the are not as durable if you do alot of hard cornering.[like slalom or autocross]
