Accetyline gas cutting question
Old Nov 13, 2011 | 05:39 AM
bboogieart's Avatar
I was cutting up a frame for parts and all of a sudden I had no pressure from the oxygen to blow out the slag. Still get a nice flame but no blow through.
The tank reads about half full, is that not enough to give me my cutting pressure? 35# to cut. Or is there something I am missing?
Old Nov 13, 2011 | 06:19 AM
mr340's Avatar
Can you adjust the oxy with the ****? If yes, I would suspect the torch blast valve in the torch head is not functioning. If you cannot get any oxy, I would look into the tank valve.
Old Nov 13, 2011 | 06:29 AM
bboogieart's Avatar
O.K. Thanks for the reply, but why would the blast valve just stop working? This torch is not even a year old. Did I do something or do they just fail?
Old Nov 13, 2011 | 01:45 PM
bboogieart's Avatar
Cleaned out the tip and we have a cut up subframe.
Didn't see the tip was clogged last night.
When it quit working, so did I.
I learned to walk away from things that frustate me.
Old Nov 13, 2011 | 05:51 PM
mr340's Avatar
I didn't suggest looking at the tip because I assumed that would be the first thing you looked at.
Old Nov 13, 2011 | 08:35 PM
bboogieart's Avatar
sure should have been,
sorry I didn't mention it right off.
went to the innernet instead of the garage this morning.
Foedoe
Mar 8, 2011 07:47 AM
67gtxclone
Oct 5, 2010 06:07 PM
Aspen
Sep 1, 2009 08:10 PM
dsmtuned
Apr 8, 2009 10:52 AM
deadkelly
Apr 1, 2009 04:58 AM
