Aluminium W2 Batten Heads
1 Attachment(s)
Hello All
Does anybody know anything about these heads? I have a chance to buy a pair and was wondering what to look out for. I’m doing a stroked 360 out to 410 and was wondering if these heads are any good? The motor will be a street/strip motor. Any help would be very appreciated. I have attached a photo of them, And this is the description in the add......Pair of aluminium W2 batten heads. They have titanium valves and retainers and 10 degree locks. The intakes are 2.065 exhaust 1.65. They have big springs but I do not know the poundage. These came from Dick Landy Industries in California. The exhaust ports have double bolt patterns so you can run normal headers or W2 or W5 headers. The heads were pressure tested and proved ok. There was a repair done on one of the pedestals with a new thread insert. These would make an enormous horse power difference to your small block. They have the same combustion chambers as J heads. Rocker gear is W2 or W5. Flow numbers can be supplied. Cheers Doug |
