another aspen question?
what are a good kind of header gasket to get,,paper type,copper ,aluminum??and they would be a standard size right? and what are the best spark plugs to get,,going to stock up for spring,,thanks
remflex gaskets never leak. just get em for the size motor you have.
with spark plugs i would prob get some platinums and prob in ngks. but your gunna get a lot of different opinions on that. |
remflex gaskets are graphite by the way.
When my 440 comes out of my Dart for a .030 over block I am going away with graphite/foil ones on it and going with a set of copper gaskets. I always use NGK plugs. The link is for big block applications but you can get them for small blocks also.
http://www.summitracing.com/parts/MRG-7167/ |
