Is anyone parting out a disc brake setup?
I need a disc brake setup from an A body. both sides.(dart, valliant, duster, demon, barracuda, etc) It needs to be the 4.5 bolt circle not the 4 inch small pattern. I am looking for the entire setup. control arms spindle everything. It doesn't have to be in great shape I can rebuild it. Thanks. Post here or Email me at: Steve@Crazy4Carz.com
I read in mopar mucle a fw months ago that you can use the front disc brake setup off of the 72-5 chargers bodies. you need the whole set up like off a dart, but the spindles place the wheel 1" higher then the a bod. setup. if this doesnt bother you, then you can go this route.
Guest
Posts: n/a
Guest
Posts: n/a
okay crazy the guy with the parts that you seek says he thinks he still gots the disc set up. and he will look and make sure. but it may be awile from the sound of it. he is just starting going thru a divorce, i told him to call me as soon as he finds out... sorry thats the best i can do. i can see if i can give you his number if that would work.
