attachment hardware
Guest
Posts: n/a
attachment hardware
hello- im new to the site. i am looking for a source where i can get the attachment studs for the side scoops on my 69 coronet rt. also, i need to get the attachment hardware for the air grabber assembly under the hood. any info or recomendations would really help
thanks jeff
thanks jeff
Did you try year-one? Other than that you could go to a place like Sears hardware that has lots of variety, and check there. Also I believe they are studs, you could take traditional screws/bolts cut off the heads and then use the stud with a nut.
