Axle stuff
Old Jan 9, 2011 | 06:00 PM
Axle stuff
As some/many of you know, I tinker with axles somewhat. Well I just happen to have come across a free D70-U rear axle out of a 1985 Dodge D350 bread truck. This is one monster axle. 4.10 gears (was behind a 4BT diesel/T19), 8 on 6.5 lug pattern with right and left hand threads, huge drum brakes, and 35 spline axle shafts. Here are some pics, I'll have more to follow (hopefully some axle shafts, axle tubes and pinion gears).
Here is a D44 carrier (left) and the D70-U carrier (right)
D44 diff cover (left) and D70-U diff cover (right)
D60 carrier (left) and D70-U carrier (right)
Old Jan 9, 2011 | 06:01 PM
Thumbs up
I may be able to cut down and re-spline the D70-U axle shafts and use them in my D44/D60 hybrid rear axle.
Old Jan 9, 2011 | 06:11 PM
damn
that is a huge rear
Old Jan 9, 2011 | 07:42 PM
Crazy4Carz.Com's Avatar
Building a dump truck?
Old Jan 9, 2011 | 07:47 PM
1966sportfury's Avatar
A.K.A Bob Dodge
i have a dana 70 with 3.54, been trying to get rid of for 10 yrs gave away and the guy never came and got it.
Old Jan 9, 2011 | 07:51 PM
Nope. I actually got it for just the spindles and hubs for a high pinion front dana 60 that I have. I ended up cutting off the inner Cs and will set it up using the D70 spindles to build a high pinion rear axle. Great for buggys, jeeps, etc. that want a better driveshaft angle and will help to get it up high off the ground.
Just happened that the axles shafts may fit my rear D44/D60 hybrid axle which would be nice. It's cheaper to cut and re-spline these axles than buying new 4340 chromo shafts. I think I've got some Ch*vy 14B full floating stuff laying around that I can compair this too as well.
505challenger
Feb 10, 2010 08:02 AM
Polara_68
Apr 17, 2009 07:48 PM
rtse66
Jan 24, 2009 04:16 PM
Doc
Aug 26, 2008 04:21 PM
ereru7
Mar 2, 2008 11:58 AM
