bad fuel pump??
Old Oct 29, 2009 | 02:45 PM
sgp7679's Avatar
Question bad fuel pump??
i was on my way to school today when my car died, popped the hood and fuel filter was dry, ok i just ran out of gas, put 1 gallon gas, runs good for 2 miles then dies right at school. popped hood and fuel filter dry again, i was thinking this cant be right, 2MPG!! i put more gas and dies again after 2 more miles, i just put 6 gallons in and filter was dry so i knew it had gas. put some starting fluid in carb and started her up. filter full of gas again, ran another 2 mins. and dead, dry filter, reprime carb restart and go 2 more mins. and dead. does this sound like my pumps going out? its mech.
Old Oct 29, 2009 | 05:00 PM
blue 68 gts's Avatar
Take a gas can, and run your fuel line from the can, to the pump and try running it. If it keeps running, you have a problem w/ most liky the fuel lines.
If it doesn't stay running and you keep running into these problems, replace the pump and filter.
Old Oct 29, 2009 | 06:57 PM
sgp7679's Avatar
got new pump ordered, will install tomorrow and see what happens
Old Oct 30, 2009 | 11:39 AM
challenger's Avatar
hey sgp is it the car in the pic or is it a car with an electric pump , if its a car with a manual pump im sure the diaphram is bad in it or the arm is worn out enough that it isnt pumping enough fuel for a period of time but if its an electric one in your tank then id pull it out and check the filter in the tank as it could be cloged but im sure it is the pump either way so change it out and im sure you will have fixed the problem
Old Oct 30, 2009 | 01:51 PM
sgp7679's Avatar
yea its the car in the pic, i replaced the pump about 8 months ago
Old Oct 31, 2009 | 03:24 AM
rr69half6bbl's Avatar
Ill go with 68 gts, try the fuel can to pump thing first, if the thing wont run its the pump, if it runs its from the pump back, sometimes, the fuel inlet tube of the sending unit has a sock on the end of it to keep crap out of the line, after time the thing starts falling apart, itll ither get sucked up into the line pluging it, causing what youre seeing. or it will cave in on itself, plugging the line then causing what your seing, the quickest way to tell is unhook the fuel line befoe the filter, and blow air back through it to the tank. then start it, if it runs, you know youll need to drop the tank and remove the sending unit and replace the sock. youll need to drop the tnk anyway to clean it out.the sock pcs. are washing around , youllneed to thoroughly clean the tank out.
Old Oct 31, 2009 | 07:34 AM
Crazy4Carz.Com's Avatar
Holy carp sell that car! Every week it's something else. I've never seen a car on any forums have so many problems.
53cranbrook
Jan 11, 2013 06:31 AM
Alexandra
May 2, 2012 12:42 PM
mopars&vampires
Jun 23, 2009 09:31 PM
skymynx
Oct 21, 2008 07:15 AM
rapidride2
Mar 20, 2007 05:58 PM
