Brake Booster
Is it possible to remove the brake booster without undoing the brake lines from the master cly.?? I'm working on a '79 D150 truck
Just use a line tool and get the what, 2? lines out of the way and the 2? bolts. The master cylinder will just pull out of the booster then
Line tool is like $15 at sears and you will be glad you got one. |
| All times are GMT -7. The time now is 08:00 AM. |
