brake lights
I just put a new brake light switch on my car and now only 1 light lights up when i apply brakes. Why would the other one not light up? it turns on when you turn night lights on.
This might be a dumb question but is the bulb good? the night lights and brake light is different filaments one could be broke and the other still work.
well i thought they ran off the same filament because of the same bulb, but i will check.
no, as stated, one bulb with two filaments and they share a ground.
put new bulb in and still no stop
was the bulk you used an 1157? it may be a bad socket or more likely, a break in the wire from the bulb to the harness. if it is the right side bulb, look between the right side wire and the left side socket. |
Originally Posted by richinny
(Post 20239)
It could be just a bulb or the ground for that side. Did it work with the old switch?
have you tested for power at the socket with a test light? sometimes the socket contacts melt into the holder and the bulb can't touch it.
