brakes
I have dana 60 rear end with 11x2 brakes .One drum is bent and it impossible to find another. Can I switch to a later year backing plate and drum set up. what years would fit on this. I knoew dana 60 and 8 3/4 are the same. Thanks
Swap to a 10x2.5 setup from any B, E,F body Should be enough adjustment in the park cables
Did you check with Rock Auto or Dave @ Roseville Chrysler , I was able to get 11x2" drums
